Octane Conversion...
Picked up part from an Octane to convert to nitro. I did this for the tranny specifically. Due to the fact that the trannys from the octane and XL really arent interchangeable I had to use the octanes chassis. No big deal because its LCG. This is my next speed truck btw. It will be powered by an ERCM picco but the F4.6 is in there for mock up purposes. Its still in the tinkering stage but I cant wait to run it. There is always a method to my madness
Not exactly, there is one mod you must do in order to convert to nitro, at this point I cannot share because im only 99% that it will work. Once ive made the initial test drive ill know if everything works as it should. Then I can share in detail what all is needed.
