shocks
Old 08-16-2005 | 05:37 PM
Default shocks
since i changed the arms on my t-maxx 2.5, the truck has been seating low. i put everything back the way it was. i thouht the shocks needed to be lubed. so i lubed them up, but it still didn't work.dose anyone know what wrong with them or what i could do so they work better???????
MONSTER_JAMZ89 is offline
Old 08-16-2005 | 10:34 PM
onefstsnake's Avatar
what arms did you change to? Prolines? Prolines sag...
Im running UE Racer X shocks. Similar to ofna threaded shocks. you need different towers though for everything to work right.
onefstsnake is offline
Old 08-17-2005 | 11:13 AM
i got arms that are almost like the stock ones. i only changed to those cuz two sides broke. i dont no why the truck started to sit low if the arms are alike. when i push down on the truck the, the truck dosent bounce back up. so i dont no whats going on.....
Old 08-17-2005 | 11:28 AM
thats strange...
Proline arms look like stock arms but they sag in the middle. check to see if you mounted everything in the right spot. there are a few mounting positions for the shocks.
Old 08-19-2005 | 11:43 AM
l checked and everything is fine. i'm sure that everything is in the right spot.
HTML code is On
