TEAM LOSI LST official thread
#422
Originally Posted by ProjectLST
Steven, where are you seeing this rule. The link I posted from the ROAR site lists .28 as the max.
i just clicked the link and your right the rule is .28,when they first came out i would swear it was .26 me and the other guys have been talking trying to decide what we were going to do.
i think it was changed or it was a mistake on my paperwork i will look for it and let you know.
as for the track we will be going by ROAR rules so .28 it is
#423
Originally Posted by stevenmichael
hey rick,
#424
Ha! Ha! I'm glad I wasn't reading it wrong. I found it under updated rules but I thought I had read the change had been requested in one of my magazines a couple months back. Are we still on for New Years Eve or is all this rain changed that?
as for working...man i dont know right now it poured sun. night,testerday and is raining as i type this now with no definite end in site.some of the guys were talking about going out there to set the poles and such but honestly it depends on the conditions if its flooded we will end up doing more harm than good.
keep an eye at the site and if all else fails i will email you
L8
steven
#426
ok guys help me out! what causes the ratcheting noise in th drivetrain.
getting frustrated thought it was in the brakes but no. got alum diff housings
foc tranny. i can take it all apart everything looks good, put it back together
and it is fine. run it and the prob is back. any ideas?
#427
#428
I've got that same sound. I've also gone to the aluminium diffs and it didn't help. I pulled the tranny apart a found some wear on the gears the feed the outdrives so I replaced the gears and placed a small teflon shim on part #B3118. The sound got a little quieter but now it's back. I phone Bill at Losi and he sent me a new set of gears but he didn't know where the sound was coming from. My neighbors LST has the same sound, we've both gone through our diff's and trannies to find the answer but everything looks fine. I guess we'll have to live with that crunching noise every time we hit the brakes
#429
I can roll it on the ground and it will bind up not even running.
#430
Registered User
Ok guys. What are the must have hop ups for this truck. I will eventually race it.
Anybody have a problem with the gear alignment? Spurs and the gears on the clutch aren't line up. They seem off by about 1/8. There's some play on the tranny shaft.
#431
One thing I just remembered, when you change to the alum. cases, you usually have to change the shim to the other side. I just can't imagine why the spur/pinion in the dif would be slipping like that unless the mesh isnt quite right. So, maybe there were a bad batch of alum. cases that went out... If its the spider gears making that noise, then the plastic cups are worn. That would be worth a check too. New Era Models, and Team Blue Star (on eBay) both make aluminum cups, and both are high quality. If you want bullit proof, get the sportsworks TiNi coated hardened steel pinion and spur to go along with the aluminum cups. They are made for the Mayhem ST, but are the exact same as the stock LST. I got mine from eHobbies.com for $62 with 2 day shipping (front and rear set).
Good luck!
Good luck!
#432
well i think i finally nailed down the noise you speak of
i had the same problem with mine locking up on me,i checked everything and ran it down to the diff cases.
when you take em apart clean em out completely(i used elec. motor spray )then look at the grooves the pins slide into,i noticed on mine the pins could turn with the torque of the of the motor trying to get them moving.
i replaced the cups on mine and put fresh fluid in and problem gone i did nothing else and it fixed it.
it was binding the diff up so bad that when i went from full power to off then back on it would flame the motor out,as soon as i replaced the cups in quit doing it.
also the noise issue,i found that with the FOC installed it made a little more noise than normal.just something i discovered and thought i would pass along.
#433
lst2 conversion kit
foc
steering servos
if it is the lst2
steering servos
foc
yes my gears were off also,wears with no problem and the tranny shaft does have a little play
#435
Foward only conversion. on the tranny or getting rid of reverse.
