clutch ??
Old 08-01-2005 | 10:51 PM
Default clutch ??
i just run my lst at my loc oval and then after refilling tank damm thing wouldnt go?
i pulled apart the clutch assembly the shoes are brocken and the nut was lose and flywheel just spinning
is this normal problem to occer?
rockn is offline
Old 08-02-2005 | 01:29 PM
Johnathan's Avatar
uh, what were you driving, and how long has it bean since you have tightened the parts? i re-tighten all of the screws and nuts i can on my
t- maxx after a long drive or race. your clutch probably fell apart from a long time without inspection/tightening, and i would simply rebuild it, and tighten the parts every once in a while. tighten everything else as well, the back of my 2.5 engines crank case comes loose after a long time as well, so just check everything for loose screws and such.
happy racing/driving!
Johnathan is offline
Old 08-02-2005 | 05:36 PM
yeah think thats wot happened its still new thou only run in
im only new to this thou im going to the lhs today so i can order parts
learning is just part of it huh
rockn is offline
HTML code is On
