Engine problem with E-maxx Mamba Monster >
Old 02-03-2014 | 10:44 AM
Default Engine problem with E-maxx Mamba Monster
Hi
I'm new here on the forum but have a question for you. I bought an E-maxx 3908L (Lipo Edition). Unfortunately I only had but trouble with it.
Is there anyone on the forum who know what is wrong with the engine? It does not go as it should. Check out my video here:
(I Cant add a video link due to that this is my first post so... Then I try this...)
https : // vimeo.com / 85749120
Sorry for my bad english.
perado is offline
Old 02-03-2014 | 11:40 AM
spookie's Avatar
Wow, that's a sick puppy. You might say it's cogging without a pinion, then the next hit of throttle, it spins up. I would be tempted to pop the end cap off the motor and take a look inside.
Here's another shortcut. Just copy and paste, the browser should insert the HTTP in front automatically.
://vimeo.com/85749120
spookie is offline
Old 02-03-2014 | 05:08 PM
whats it do with the pinion on the truck?
Brokenparts is offline
Old 02-03-2014 | 10:09 PM
With the pinion it doesnt move. There are no force in the engine when it starts doing this. Maybe there is some crap in the engine that creates this "cogging"?
Before it worked OK but after a while this happend and I thought it was a problem with the clutch. The first error I had with the car was a faulty adjusted clutch! So mutch for RTR! I burned down the clutch within a cuple of minutes. Second "problem" was a exploding tire (my own fault, I think). Now this...
I have two other Traxxas products that I NEVER have had any problems with so this is not funny at all. You think you buy a good product and this happens. This car have not drained it first batteries yet...
perado is offline
Old 02-04-2014 | 12:55 AM
Contact Castle or Traxxas, they should be able to sort you out.
TheKennyKiller is offline
Old 02-04-2014 | 08:17 AM
I have sent an support mail to Traxxas and waiting for answer. I will keep you updated.
perado is offline
Old 02-06-2014 | 07:50 AM
OfnaJoe's Avatar
1st thing I would do is try another battery or make sure the one your using has a full charge. Make sure what your low voltage cutoff is set at. And maybe rebind the radio to the esc. Or call Castle customer service, they will walk you thru everything on the phone. Good luck
OfnaJoe is offline
Old 02-07-2014 | 12:12 AM
Thanks. I will try that since Traxxas is not responding to my supportmail.
perado is offline
Old 02-08-2014 | 11:16 PM
tdevilman420's Avatar
Give traxxas a few days they will respond cant answer the question u have but last time i emailed traxxas it took bout three days befor hearing back.as for the motor deff sounds like something not right
tdevilman420 is offline
HTML code is On
