New member
Hell there,
Im new to the forum. I recently did a electric conversion to my pro .15 t maxx. my tmaxx is definitely not stock tho. It had a 3.3 on it but got tired of tuning the dame thing. I am really new to the whole electric stuff so i want to keep the 45-50 mph that is had but i don't want to pay a fortune. I currently have a 540 motor out of my drift car but i had to tune the esc to make it run so i haven't had the chance to play with it yet. |
you're not going to be able to run it with the 540, for the Tmax you will need a 1/8 system, the system from your drifter will burn up pretty quick. If you are on a budget check out HobbyKing or Falcon Sekeido (HobbyWing).
So the 540 will probably push it along but will burn up cause the tmaxx weight is to much? And thanks for the reply.
Would this be ideal for a good set up? And what else would i have to do(metal tranny gears or cvd's) to the truck.
HobbyKing Brushless System Model:HK4074 Sensorless ESC Features: • Suitable for sensored and sensorless brushless motors • Adjustable acceleration and braking levels • Adjustable timing allows for fine tuning • Unique built in cooling fan for increased heat dissipation • Low voltage protection ESC Specs: Continuous Current: 150A Burst Current: 1080A Suitable Car: 1/8th scale truck, car, buggy Battery: 2-4 cells Lipo, 6-18 cells NI-xx BEC Output: 6V/3A switch mode built-in Motor Type: Sensorless and sensored brushless motors Running Mode: Forward only / forward with reverse Dimension: 57 x 48 x 44mm Weight: 158g Motor Specs: Model: HK4074 Sensorless Pole Count: 4 Kv: 2150 Scale: 1/8th Weight: 380g Diameter: 40mm Length: 74mm Shaft Diameter: 5mm Sorry i cant post URL's yet. |
that sounds more suited to what you want to do, pair that with a 4 cell lipo and you should be golden. I don't think you will have to upgrade anything else right off the bat, just worry about that stuff as it breaks
As a thought...for a bit more money you can get Hobbywing...which from my research and experience has better support, is waterproof and is true 1/8 scale. Notice on those hobbyking esc's how the wires are puny? That's got loss of amps written all over it.
Or good old castle....the 2200 rips and roars in the maxx |
| All times are GMT -7. It is currently 04:57 AM. |
