summit advice
You fill them almost to the top as the spider gear on the ring gear side will displace some of the fluid. If you put too much in the excess will just be pushed out. But yeah you want them filled
If you're using a Summit for it's intended purpose, when the diffs are open and you can't get over something like a rock or a log you lock them up.
BTW I've done plenty of bashing with a permanently locked rear diff in my BL E-Revo and the only thing I've busted is driveshafts.
