the classic flm emaxx and rpm build/comments & thoughts
#136
The big bore work great. I see some improvement from them since I changed how I had them fastened to the lower a arm. I run the big bores with 45wt fluid and VG racing springs. Works fine which is why I haven't changed them over to buggy shocks yet. The flm chassis comes with battery straps. I broke one finally last weekend and went to home depot, bought some velcro and works fine.
For the diff's, if its never been ran than I guess leave them alone. I would just be curious if they were shimmed or shimmed properly. The 1/8 diff conversion will use 6mm or 8mm and 10mm shims. I'd have to look later to be 100% on that. I know the diff cup will use the 10mm and the pinion will use 8mm but the out drives from the cup I can't remember if they are 6mm I believe they are. I can check tonight bud
#137
Yah flm doesn't really deal with people first hand. Emailing will be the best way to contact them. I understand, when building mine o had packages after packages. Its was exciting and I love the truck.
When you shim the diff, the objective is to eliminate all play out of the diff. That's play with the pinion and spur (pinion moving g back and fourth). Then play with the diff cup (side to side in the housing) but also this sets your mesh between the too as well.
#138
Alright guys....been some time but I have been playing with this rig ever since the completed build. I have since a few weeks ago, rebuilt everything with new single monster 2270 savox servo. Added a cc 1717 1650kv motor with an unlocked xo-1 extreme esc with my cc bec. I ruined my trenchers and taped up some mashers which don't balloon at a all. Upgraded to a new spectrum Rx, this truck is a blast to drive every time. I have also since bumped up from 4s to 5s......seems like the sweet spot. That old mm2 system and 2200kv motor got dropped into a slash 4x4 I bought......and man that thing is a beast on 4s aswell!!!
Hope y'all like what I have done. Against his is by no means a shelf queen, it never has and never will!
I have since added the new servo but haven't added a new pic.
#139
I also about a week ago performed a mod on the 17mm wheel hexes to eliminate the wheel slop. After a yr of driving the ID of the wheel hex as worn from the axle threads, causing excessive wheel wobble. So I have added a bress insert and drilled the hex out to put these in and since as got rid of all the slop in the hub!!!
This is before I filed those inserts down to fit inside the hub.
My jig to drill the hub out with a 6mm bit.
Insert is applied to the hub
#140
Are those Axial posts threaded all the way through?
Are they 3mm threads or 4mm?
#141
Sorry for the long reply. They are 3mm threads. Use a 45mm post with a spacer on either side. Axial part #'s - axa1412 and axa1426
#143
Here is a current update of my build. Instead of reposting I added a link from the traxxas forum where I have my info posted. I started outfitting with lst diffs. If anyone is interested.
https://traxxas.com/forums/showthread.php?9033787-Emaxx-CC1717-from-xo-1-1650kv/page2
#144
https://traxxas.com/forums/showthrea...1-1650kv/page2
#145
Since building my lst I have lost interest in my emaxx. So it's been sitting as a roller for some time now. I just recently took a beach trip and lost my slash in the ocean.....very odd and sad it happened. But either way, I want it back and I don't have a need for this emaxx anymore. I'd like to part ways with it if anyone is interested in it. I'd prefer to sell it as a roller but if no interest then I guess I could part it out. Send me a pm and if I get enough interest I can start a for sale add.
