Brushless Issue
Hey guys,
I threw a Reedy brushless system from a TA SC10 in my Traxxas Monster Jam truck running 2s lipo.
90t spur and 16 pinion.
I was checking temps and they got to about 165 F.
But after about 20-25 mins of running and jumping the truck slowed to barely anything and I noticed a tiny bit of smoke from the motor. Again it was about 165F.
I let it cool and then tried again (for about 15 seconds) and it ran again.
Any ideas on what happened?
Should I look at my gearing?
Here's the possible problem (and this might not be your problem) I see and IMO your gearing is fine.... "Sometimes" once a BL motor has been heated up beyond 200 degrees, they loose mass amounts of efficiency meaning they require more power to be pulled to achieve the same results; speed/torque and HP. For the laymen's, ultimately what ends up happening is they heat up quicker. Not to mention, when you temp a motor you get the outside heat, not the internal heat where it's most important.
165 is not something to worry about if your constantly on the throttle for a packs entirety. Unfortunately one can not tell if a BL motor was ran in those temp ranges before one purchases it used.
Thanks for the insight mate. I was assured by a very good 'trader rating' seller than the esc and motor were kept in A1 condition and always at good temps. Hopefully he was telling the truth. Lol.
There is such a thing as under geared overheating too. You find yourself constantly pulling all the throttle to get the speeds your used to. Gearing up would/could eliminate full throttle all the time. Try it out. When you were at 165 on the motor can, what was the ESC temp?
Forgot to mention I was running on tar road and grass (mainly road), with a bit of short, sharp accelerating (jumping, wheelies etc) and a couple of longer speed runs (dragging my neighbours nitro buggy).
