LiPo help
Old 04-22-2013 | 04:58 PM
fr8cture's Avatar
Default LiPo help
Alright so today I went and ran my e-revo and surprisingly I didn't break anything major but I did break the traxxas wheelie bar and the rear bumper mount. I went to charge the packs and my charger is saying one battery is way out of balance how can I fix this? I have a really low grade charger, it doesn't have a discharge option or anything. Just an option to charge 1s,2s,3s.
fr8cture is offline
Old 04-22-2013 | 07:34 PM
bigbadbasher's Avatar
No balancer? Man, if your gonna run LiPo your going to want to keep them balanced.
bigbadbasher is offline
Old 04-22-2013 | 07:36 PM
fr8cture's Avatar
It has the balancer but I can't balance a single cell...
fr8cture is offline
Old 04-22-2013 | 07:38 PM
im confused, are you running a 1s lipo in a e revo? 0_o
plug it into the balance port and it should balance it..
Old 04-22-2013 | 07:43 PM
fr8cture's Avatar
I am running 2s and I do plug in the balancer but its too unbalanced for the charger to charge it. Anyways I charged it for a bit without the balancer then I plugged the balancer in and its charging fine now...
fr8cture is offline
Old 04-22-2013 | 09:26 PM
Most chargers (even the cheap ones) have circuitry preventing the charging of a Lipo if one of the cells is bellow 3.0 volts. Double check esc cutoff settings and maybe raise it a little if it occurs again.
Overdriven is offline
Old 04-22-2013 | 09:44 PM
Not sure what electronics you are running in your revo, but my guess would be 2s is WAY underpowered and can not deliver the power demand thus pulling your battery out of whack. If your running the mamba monster I wouldn't go <4s.
big JC is offline
Old 04-22-2013 | 09:59 PM
fr8cture's Avatar
I have 2 2s in series. So 4s total. MMM 2200kv stock electronics.
fr8cture is offline
Old 04-23-2013 | 07:36 AM
Oh, here you gave me the impression you were running 2s. May have run it to low, or possibly didn't have both packs fully charged which can run the low pack wonky. Also as your packs get a lot of runs on them they can become mismatched which can run one of them wonky. I like to test all my cells periodically with a voltage tester before, after charging, and after running to know for sure where they are at.
big JC is offline
Old 04-25-2013 | 12:58 PM
Cain's Avatar
Tech Legend
curious, what settings do you have for lipo-cutoff on your speed control?
as a tip, I would recommend you do hard cutoff setttings and NOT rely on the ESC to autodetect the packs.
I would also set the cutoff to the equivalent of 3.4V per cell. That shoudl give you some cushion and help your batteries out. So on 4S, that would be 13.6V total. And remember that when you hit cutoff, its a soft cutoff from what I recall, so don't keep running around. bring it in, shut her down.
Cain is offline
HTML code is On
