Motor Help Needed >
Motor Help Needed
Motor Help Needed
Old 10-11-2012 | 09:47 PM
SteelAce's Avatar
Default Motor Help Needed
Today I had my Groud Pounder out and decided to do some mud bogging. Long story short.. I burnt up the stock motor.
What would be a good cheap replacement? I am using an Arrma esc and am running the truck on Nihm packs. A motor that is somewhat sage near mud or water would be nice. Also a little more speed will be nice too.
SteelAce is offline
Old 10-12-2012 | 09:48 AM
SteelAce's Avatar
Anyone? Really do need help with,this
SteelAce is offline
Old 10-12-2012 | 02:58 PM
Idk for sure but the motor is probably a 27 turn, dropping down to a 19-21 turn should increase performance without totally killing run time. A 550 sized motor is another option. Just heck the ratings for the esc to make sure it can handle the motor hou choose. No motor exactly likes mud and water though. You should really wash the motor out a bit after mud running, then dry it with some compressed air and put a couple drops of oil on the bearings/bushings.
Overdriven is offline
Old 10-12-2012 | 04:13 PM
SteelAce's Avatar
I know this esc can handel a15 turn. I might just stay away from mud now lol
SteelAce is offline
Old 10-12-2012 | 04:17 PM
mojoman81's Avatar
Here you go
http://www.trinityrc.net/shop/index....ry&path=72_114
mojoman81 is offline
Old 10-12-2012 | 07:35 PM
SteelAce's Avatar
Originally Posted by mojoman81
Thanks for the link mojo. Thought they discontinued speedgems.. Anywho, rhat 19t should be ok right?
SteelAce is offline
Old 10-13-2012 | 04:42 PM
hotrod87's Avatar
An emaxx motor would be a good choice also. I had one in a groundpounder. Worked good.
hotrod87 is offline
Old 10-13-2012 | 07:30 PM
SteelAce's Avatar
Did tou have to change the pinion gear?
SteelAce is offline
Old 10-13-2012 | 08:16 PM
hotrod87's Avatar
I honestly can't remember what gearing I ran in it . I think it was a 17 tooth.
hotrod87 is offline
HTML code is On
