3.3 help
Revo. Almost new 3.3 engine. Running Byrons 30%
I recently put truggy tires on it. It was only shifting into 2nd occasionally. I put a larger spur gear on it. Wasn't shifting at all.
Glow plug died, I replaced. Went on to burn up 2 more plugs. I chalked this up to running too lean. The piston and button show imbeded bits of filament.
I went back to stock settings on carb and have adjusted every which way since. The engine will only start up at full throttle and will cut out as soon as I release throttle.
I have tried an extra shim. With and without, no change.
What can I do?
What can I do?
What can I do?
What can I do?
I put new shoes and clutch bearing in. Needed them bad! Fired up fairly easily and ran. Still wasn't shifting. After some "tuning" it kinda stopped running again. Still havent put my other head on it.
Man, right when I was really starting to get back into my Revo, she craps out.
...2 shims should be good
