savage center diff? >
savage center diff?
savage center diff?
Old 05-06-2012 | 08:50 PM
The Pope NJ's Avatar
Default savage center diff?
I have made a center Diff for my savages that goes inside the transmission on the final drive so that you still have the functions of the two or three speed if I want or I can just run a High speed flux idler gear and race my savage in the truggy class legal like
However this is where the issue comes in once I put it in the truck I loose front breaks. Anyone have any ideas on how to attach breaks to the front drive? Anything from a buggy or truggy that you may know of would be helpful just trying to brainstrom ideas.
The Pope NJ is offline
Old 05-08-2012 | 11:46 AM
LSVTIEG's Avatar
Lets see pics of this mod. I would like to put a center diff in both my savages.
LSVTIEG is offline
Old 05-08-2012 | 01:08 PM
Stubbs's Avatar
+ 1, I'd like to see this too....
Stubbs is offline
Old 05-08-2012 | 01:49 PM
Snook Man's Avatar
I’ve added a center diff to the Tmaxx transmission and had to fabricate a rear brake setup.
Not a lot you can do other than start measuring and cutting some adapters out of whatever is necessary to mount the calipers/pads and disk to the tranny housing and/or the chassis.
Designing the rear brake was harder than adding the 1/8th scale diff inside the transmission.
Snook Man is offline
Old 05-08-2012 | 02:01 PM
All I did was find a diff housing that would fit in the bottom of the trans case. Cut the shaft in half that runs through it and machined and drilled the ends down to fit in the diff case. Used a blank sheet of alum to seal the diff case and drill the bottom gear to bolt to the diff case. Simple and took less than 2 hours. I believe the diff case was out of some 1/10 scale
Old 05-08-2012 | 02:08 PM
I will snap some pics next time I take the trans down.
Old 05-09-2012 | 12:22 AM
please take it down soon I cant wait to see the mod!!!! I have a CD in my savage but I had to throw the trans away.
johny723 is offline
HTML code is On
