t maxx problems/issues!
#16
Yeah, I remember telling you this would happen a loooooong time ago but NOOOOOO, you had to have a blue servo......
I got a question for you, you got all that money tied up in that thing, all that blue, all that sparkly bling bling, all that anodized aluminum ETC, ETC..
Are you ever going to drive that thing like it was ment to be driven?
Off road
Dirt
Big air
Any of that or is this thing going to sit on a bench somewhere in the garage for the "once in a while start up", run down a flat street and back in the garage?
#17
Your servo is probably fine actually. When you have all the gears off, you'll notice there is a brass piece that keys into the main output gear (the one with the splines for a servo arm). That part lets the servo know where the output gear is, like 0*, 30*, 60* (out of 360*) etc.... So if you go back and try it again, turn that piece of brass, you'll notice the motor will stop when you have the brass piece centered, that is how the servo motor knows its centered, and it stops turning. If I was at home I'd take a pic, but I think you can understand what I mean.
im just going to get another 2075 or if i can get the money im going with that savox i listed above. thanks for the info though.
#18
Off road
Dirt
Big air
im totally against shelf queens! to put alllll that money in something then let it set
noooo way! i feel the same way when people build up a 1:1 car/truck and trailer it around. get out and drive it!
