Juggernaut 2
Old 06-17-2002 | 08:19 AM
work's Avatar
Default Juggernaut 2
I'm getting a jugg2. What do you guys think about the ESP leb kit?
work is offline
Old 06-17-2002 | 08:21 AM
work's Avatar
Sorry I mean lwb kit (longwheel base kit)
work is offline
Old 06-18-2002 | 04:05 AM
it is definitely a good hopup. one of our local racers has a jug2 with the ESP LWB kit, chassis kit, swaybars, and more. i think he runs it in QC circle. i used to have a jug2 with a homemade LWB kit. but i had problems with the stock body because it was too heavy. after installing a lexan body, the jug2 handled a bit better. if you get a LWB kit, i suggest that you also install swaybars. i think you can get them separately from ESP.
marvi is offline
Old 06-19-2002 | 06:09 AM
work's Avatar
Thanks for that suggestion. Any advice on Jugg2 bumpers? My sister ran my Jugg head on to a cement wall Nothing really serious just a bent bumper
work is offline
Old 06-19-2002 | 06:31 PM
which one, the lower bumper? im not sure if there are aftermarket protective bumpers that will fit those. to protect from scratching the aluminum bumpers, you can use 3M stickers but they wont do too much to prevent bending.
with some modification, maybe you can fit TXT front and rear bumpers to the jug2's chassis. these bumpers extend a bit past the front and rear tires and they really protect the truck in head-on crashes. but i doubt if theyre available in our lhs. try mail order from tower if they have those.
marvi is offline
Old 06-24-2002 | 08:23 AM
work's Avatar
Yup, its the lower bumper. Anyway I just hammered it back to its original form
I'll try to see if I could install those TXT bumpers. Do you experience any steering problems on the Jugg? Every time I bump mine, the servo would either go extreme right or extreme left and not go back
work is offline
Old 06-24-2002 | 11:48 PM
no, i havent had any problems with the steering, even with the long wheelbase conversion. maybe the servo savers are too tight. also, try adjusting your steering ATV (if your radio has that adjustment) because sometimes, the servo over-extends and it doesnt center at once. what servo are you using? another cause would be the servo is not strong enough to turn the wheels back to center.
marvi is offline
Old 06-26-2002 | 03:09 AM
work's Avatar
Alright thanks, I'll go check my servo saver and my ATV. I'm not sure what servo I have on it because I just borrowed it. I'm planning to get a Hitec mg servo.
work is offline
Old 07-07-2002 | 06:52 PM
Dongskie's Avatar
Work: Please post some pics of your Jugg...
Dongskie is offline
Old 07-08-2002 | 03:02 AM
work's Avatar
I cant attach the pics forwarded to me by the previous owner because its a word document file. I'll just email it to you
work is offline
Old 01-09-2011 | 05:34 PM
bigb11's Avatar
I have one for sale - pm me.
Attached Thumbnails Juggernaut 2-picture-8126.jpg1.jpg   Juggernaut 2-picture-8124.jpg1.jpg   Juggernaut 2-picture-8123.jpg1.jpg
bigb11 is offline
HTML code is On
