tmaxx
Hi this is my first post i have a tmaxx with a trx pro 15 engine in an it kept stripping spur gears so i bought a steel spur an now its stripping the clutch bell gear does anyone know how i can prevent it from doing it any help will be much appreciated atb ade
You have to push the whole gear into the spur as tight as you can get it with the engine and mount as straight as possible. Then you want to back the gear out of the spur keeping the engine and mount as straight as possible just enough to let it spin free with no binding.
Basically you want as much tooth biting the spur with the least amount of binding. Almost sounded like you were using 2 different gear pitches
