Tuning Question
im running a savage with the f4.6 engine and it was given to me used so the tune on it needed to be changed for my area.....long story short the tune was all out of wack so i reset the carb back to factory settings.....1mm idle gap, hsn flush with housing and lsn flush with housing. now it fires up on the 1st or 2nd pull and idles fine, but as soon as i remove the glow ignitor the engine dies.....anybody have any ideas?
Originally Posted by marleyg
(Post 9520733)
Sounds a lil rich... try leaning out your lsn just a little and if this doesnt work after 3/4th turn in 1/8 incriments... move to your glow plug... Watch these VIDEOS you will feel like a pro afterwords...
http://www.youtube.com/user/Squirrel.../0/WOZiU265FKE |
ive tried 2 different brand new plugs.....im hoping that my glow ignitor is not fully charged and isnt getting the plug hot enough....even compared the "bad plugs" to the new ones and they are still excellent
almost had it figured out.....then.........this ---> http://img842.imageshack.us/img842/2...cture0042t.jpg
awww daymn that sucks..... thats why you should use bump start... you never worry about that... and less drag so your motor runs better.... I honestly think its your LSN...
cant bump start a savage..... and its def my lsn....got it to idle for about 10 seconds with the ignitor off before the pull start snapped....now ive got the worst headache.....im done with it for the day....i need a smoke
Im pretty sure I have seen adapters.... maybe look into roto start....
Originally Posted by TIZAO
(Post 9521431)
| All times are GMT -7. It is currently 02:55 PM. |
