Too much compression?? >
Old 06-01-2011 | 10:48 AM
Default Too much compression??
I installed a new engine in my savage (hot bodies .26) and I've broken it in. The engine has so much compression that it's very hard to start and I keep breaking the pull start rope..? What should I do?
norco kid is offline
Old 06-01-2011 | 10:54 AM
Brushlessboy16's Avatar
Preheat the block to loosen pinch before you try starting it.
If not- aircraft 1/16in braided steel cable
Brushlessboy16 is offline
Old 06-01-2011 | 11:26 AM
10 Gauge's Avatar
Convert to rotostart
10 Gauge is offline
Old 06-01-2011 | 01:10 PM
triplebvalp's Avatar
You can also unscrew the glow plug ... about a quarter turn, start the engine, then tighten the plug.
triplebvalp is offline
Old 06-01-2011 | 07:07 PM
Make sure there is some ARO in the cylinder to start with, then use a heat gun to preheat the block. If its still hard to pull over, loosen the glow plug 1/4r from tight and see if thats enough. As soon as it fires, tighten the plug.
Soon as it gets a little run time, things will loosen up and it won't be such a PIA to crank. That engine has a rep for this. Enjoy...
Duster_360 is offline
Old 06-01-2011 | 08:05 PM
shizcol's Avatar
Yup works every time for me..
shizcol is offline
Old 06-01-2011 | 08:42 PM
Cummins Driver's Avatar
And beat your one way bearing to a pulp
I guess roto start's are ok, but i prefer a good working pullstart, and they are much nicer to your one way bearing
Cummins Driver is offline
Old 06-02-2011 | 06:00 AM
Good and easy..
PP22 is offline
Old 06-03-2011 | 01:07 AM
SLAYERDUDE's Avatar
That and lean it out a bit from stock settings, sometimes they are too rich from the factory for breakin.
Depends on your weather...
SLAYERDUDE is offline
Old 06-03-2011 | 01:27 AM
Trugsta's Avatar
Default Thats the only Reall way..
Heat is your friend when starting a new motor.
heat up the block to atleast 70c before starting and you will never have a problem.
Oh and be sure the motor is primed blow through the exaust line untill the fuel is at the carb then give the cord a yank..
Trugsta is offline
Old 06-04-2011 | 04:46 PM
Upgrade the oneway and put a good torq starter on it. I use my snapon 3/8 impact with a 12" extension on my Warhead Evo Super Tigre 4.4 Fires everytime in under 20seconds
Now if the parts would come in for the restore to be complete.
Sstroudwku is offline
Old 06-07-2011 | 08:20 PM
Jstall7543's Avatar
Make sure your engine isn't stopped at TDC, this will snap your cord if you yank to hard. Rotate the flywheel with your hand past the compression stroke. Or do everything stated above.
Jstall7543 is offline
Old 06-08-2011 | 04:25 PM
If it's that tough to pull then you must be over-priming it.
trxnut454 is offline
HTML code is On
