Buying a Losi LST XXL - Thoughts/Tips/Tricks
#76
And then you need this: http://cgi.ebay.com/Team-Losi-XXL-Li...item5ae006e788
Which has the steering servo links you need.
Then depending on what servo/brand you run, Ill tell you if you just need insert splines, or an upgraded servo saver pair.
#77
OK, then you need this if you dont have it already: http://cgi.ebay.com/Team-Losi-XXL-Be...item5ae006e6a3
For servos I was thinking of running two of these, unless you have something better in the $20 range
http://www.hobbyking.com/hobbyking/s...idProduct=9441
#78
Cool, thanks man, The bell cranks are there I have those. The 2nd link is what i need. Or should i just get the upgraded associated servo savers?
#79
parts
you could try dollar hobby.
