emaxx acceleration problem >
Old 02-15-2011 | 07:32 PM
Default emaxx acceleration problem
first off its the brushless edition...anyways for some reason i can start to accelerate then it like drops into neutral then it slams into gear....at any throttle pressure to..its not the slipper clutch it was pretty tight...it is so bad it acctually snapped both of the pinion gears i put on it......after it does its little hesitation it seems to run fine tho...the drivetrains pretty stock to....any help would be appreciated guys
michaelr2587 is offline
Old 02-16-2011 | 11:36 AM
team jeremiah's Avatar
what kind of batteries are you using?
team jeremiah is offline
Old 02-16-2011 | 07:15 PM
Are you running lipos or NiMhs?
Duster_360 is offline
HTML code is On
