-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   Single Sub-C question (https://www.rctech.net/forum/monster-trucks/465569-single-sub-c-question.html)
erocki 12-28-2010 04:52 PM
I have a couple Integy 4100 NIMH 6-cell 7.2V packs that started to drop. I found one Single Cell in each pack that reversed polarity. I was able to jump start one of the by hitting it with two seconds off a 12V battery and it is holding at 1.27v nicely. The other one I hit a few times and it goes up to about .90v or so but then drops the charge right away. My question is that I am trying to find one Single Cell 4100 NIMH to replace this dead cell but can't seem to find anyone who cells them anywhere. Does anyone know where I can pick one of these up or do you think someone around here might have one that i could purchase? I have tried the usual sources like All-Battery, Battery Junction, etc. but no luck.
Thanks in forward for your help....
Erik
got_nitro 12-28-2010 05:40 PM
Seriously, I would not even mess with that. I would count my losses and move on to bigger and better things. Your talking about integy here, not pro-match. You would have to find the exact mah cell.
If you want to stick to NiMh packs, Pro-match are the best cells you can buy. Even the un-matched cells are probably the best around. If you have a cell go bad with these packs, you can replace the bad one. You can buy your cells and build your own packs too.
http://www.promatchracing.com/products.php?cat=9
