Bubbles from Head >
Bubbles from Head
Bubbles from Head
Old 12-05-2010 | 03:16 PM
Bighomedog11's Avatar
Default Bubbles from Head
Hey I am wondering why does my 3.3 tmaxx do this. I notice when i drive it around and i am trying to tune it. I notice that fuel will start bubbling up from the top of the head. I am wondering could the glow plug not be tight enough?
Bighomedog11 is offline
Old 12-05-2010 | 04:01 PM
Ryan86's Avatar
I take its coming from the glow plug hole.
2 things i can think of is 1, you need a new copper seal for the glow plug and 2, maybe the thread on the head has stripped a bit? over tightening the glow plug?
Ryan86 is offline
Old 12-05-2010 | 04:44 PM
The seal can wear out? Becuase i have the glow plug in for a few months now. But i dont think the head is stripped because i never remove to glow-plug. Well i removed it once, it might need to be tighten up more.
Old 12-05-2010 | 05:00 PM
Prob plug is loose. You need to check the plug every once in a while to make sure its tight. These things vibrate so things come loose, reason you use loctite.
Duster_360 is offline
Old 12-05-2010 | 05:55 PM
mgtmadness2007's Avatar
Also check head bolts/screws, make sure they are tight. Most likely it is the glow plug not tight enough/ or stripped like the others said.
mgtmadness2007 is offline
Old 12-05-2010 | 06:18 PM
Oh, Well i will check tomorrow and make sure the plug is tight.
Could this cause a bad tuneing?
Old 12-05-2010 | 07:17 PM
No, it may just lose a little power. It used to be a common thing to loosen the plug on motors with real tight pinch so they would be easier to start.
Nothing really to do with tune.
Old 12-05-2010 | 07:53 PM
Alright, Well i will check and make sure it is tighten tomorrow.
Old 12-06-2010 | 07:05 PM
Just be careful and make sure you don't strip it. Its in alum and its not that hard to strip.
Old 12-06-2010 | 07:58 PM
Stubbs's Avatar
This is probably already obvious to you, but I'll state it out loud to be sure. In no case should you ever put loc-tite on your glow plug......
Stubbs is offline
Old 12-07-2010 | 04:59 AM
For the obvious, correct, don't use loctite on the glow plug.
That should be obvious to anyone running nitro.........
HTML code is On
