Help with crank >
Help with crank
Help with crank
Old 06-29-2010 | 09:34 AM
718Timdog's Avatar
Default Help with crank
Hey I would like to know if anyone how to polish a Crankshaft ??
718Timdog is offline
Old 06-30-2010 | 07:53 AM
jakerz's Avatar
go to voodoomodified.com, they will hook it up for you
jakerz is offline
Old 06-30-2010 | 09:21 AM
"Help with polishing my crank" Awesome!
CICreations is offline
Old 07-01-2010 | 06:56 PM
718Timdog's Avatar
humm i want to try to do it my self but i wanna know what do you need and how to do it
Old 07-04-2010 | 03:46 PM
Honestly. Don't polish an entire item. Ever. Your actually better of sandblasting the crank then polishing it. Well, with a very fine glass media, and not near any connection and/or bearing mount surface. Counter intuitive?
Pass-through from the carburetor port, teardrops and flairs from the pass-through, and counterweight scoop, should be polished. Everything else on a crank should have a slightly rough texture to it. Yes polishing increases flow-rates in some areas. But it also lowers turbulence, (Remember, we want turbulence as to get a good mixture) and smooth surfaces let droplets form much easier.
The same goes for the inside of the crank case. The transfer channels can/should be polished, anything else should not. Well, actually the areas where it should seal could in theory benefit from polishing as well but only at the cost of removing material, so leave them alone.
And the same again is true for the conrod, and the inside of the piston.
B!
Mr B is offline
HTML code is On
