E-maxx Issues.. 3906 >
Old 06-18-2010 | 06:29 AM
ANX's Avatar
ANX
Default E-maxx Issues.. 3906
Hey
I just recently got a second hand E-maxx for my beginner friend. So I tried it out with the following:
- 2x 2s 5200 30C LiPo's
- stock EVX-1 ESC
- two E-savage GT550 motors..
- And a cheap 2.4Ghz set.
It runs fine, although everytime I try to do a wheelie (punch the throttle) it just lurches a few cm and won't go..and the only way to go forward is to ease the throttle..
Just wondering what the problem could be... I used to have an E-maxx too and it would do wheelies without a problem.. (Have tightened the slipper too)
Pls LMK if you have any input.
Thanks in advance.
ANX is offline
Old 06-18-2010 | 08:47 AM
either the motors are drawing too much ...
or and it sounds more like this,
the esc is damaged.
try swapping it out for an other one if you can.
traxass has good support for repairs if you send it in.
if it does the same after swapping out ... keep changing parts
could be the radio to! but start with esc
any loose or week connection could be failing when you try to open the throotle hard.
but most likely inside the esc that it is happening
let us know what you find.
sometimes it is the last thing that you think of that does not make sense it could be that ... but it is!
rc everywhere is offline
Old 06-18-2010 | 10:04 AM
The lipos look good enough spec wise, that there shouldn't be prob with amp draw, so either it's a bad connection somewhere or the esc is having probs. Might try to re-program the esc to see if it helps.
Duster_360 is offline
Old 06-18-2010 | 10:19 AM
Justpassedu's Avatar
Try tightening your slipper clutch down and check the pads on it and pressure plate , this could also be the issue ... Oh just saw you checked your slipper , maybe the pads or pressure plate are worn down , take a look...
Justpassedu is offline
Old 06-18-2010 | 11:36 AM
LunchboX3904's Avatar
not sure about the evx-1, but the evx-2 is known for cutting the power on freshly charged lipos and i experience this as well. ease on the throttle for the first 1-2 minutes and then you should be able to punch it from a stand still
LunchboX3904 is offline
Old 06-18-2010 | 01:06 PM
I've run my 3906 EVX-1 (the old red one) on 2 5000mah 35C Intellect lipos and mine has never done that, never has hesitated even with a pr of freshly charged 7 cell pacs reading more than 20v.
Old 06-19-2010 | 12:09 AM
ANX's Avatar
ANX
Hey Guys
Thanks for all the help..
I asked the original seller and he said to try reset the ESC and re-calibrate with the 2.4Ghz..
Will try do it soon.
Thanks again for the help
Hope it works
ANX is offline
Old 06-19-2010 | 07:01 AM
If you've changed radio and not re-calibrated, then that is an issue. You have to re-cal when you change components.
Old 06-26-2010 | 09:06 AM
Originally Posted by alicegzc
Discount Baby Phat by Kimora Lee Simmons! Dresses, Tops, Shoes & More on SaleWe Have Clothing & Accessories. wholesaleBaby Phat Clothing on Sale.
Just what I needed!
reported.
Old 06-26-2010 | 09:15 AM
Xmod_Racer's Avatar
thats probably what is making his esc glitch....
Xmod_Racer is offline
Old 06-26-2010 | 10:33 AM
Originally Posted by LunchboX3904
Just what I needed!
reported.
Thanks! Looks like it has already been taken care of.....dumb spammers....
HTML code is On
