-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   TMaxx Conversion Question (https://www.rctech.net/forum/monster-trucks/387624-tmaxx-conversion-question.html)
Loveme_some RC 04-08-2010 04:28 PM
I have an older 2.5 & am changing it over to Electric. Will the Trans off an E-Maxx 3906 directly fit? I remember seeing some stuff on this on the site, but I can not find it anywhere.
junkman12 04-08-2010 08:17 PM
yes, the 3906 trans will bolt right in. Fix you up some battery straps, and consider yourself converted.
Loveme_some RC 04-09-2010 07:42 AM
Thanks:D. That is what I thought. Do you know if I will have to "bulletproof" the gears inside the trans? I have a spare Velinion 3500 & not sure if the trans will hold up.
junkman12 04-09-2010 11:30 AM
The trans should hold up fine, there are some roll pins on the input shaft that you may have problems with, but you can replace them with a piece of drill bit, or allen wrench. That should strengthen it up pretty well. I ran a 8xl/4s combo on one for a long time.
Duster_360 04-09-2010 12:26 PM
I'd be more concerned about the diffs and drive axles than the trans - def replace that roll pin in the top shaft of emaxx trans - they are easier to replace new than after the pin has been destroyed - and teh torque from a good BL setup will shear it off.
Its an easy job especially since you'll have the trans out to start with.
