savage xl transmission problem ( Please help)
i just got my savage xl and i am having a problem with the transmission. the engine would rev but the car would not move, I tightened the slipper clutch all the way but i am having the same problem, i would work for a second but then would slip again and not move, only the engine would rev.. it would only re-engage again if i stop the engine and start again.. and then would work fine for a couple of seconds and then slip again.
I inspected all the truck and cant find something wrong.. don't know what to look for. I opened the transmission and its brand new, no problem with my bearings or teeth of the gears .. what should i look for, this is really depressing, please help
hi im having the same problem just finished the break in and when i started to rev on the track it just wont move.but if i give it a push it runs normally for some time and gets stuck again. any help is appreciated
thanks
thanks
Sounds like the one way bearing in the tranny is slipping. Does your tranny have oil in it like it come from the factory with pre-lube on it? If so try cleaning it out real good and try it. If not just replace the one way tranny bearing.
