Not getting full power to the wheels
Something is not right with the monster still. I don't know what is going on with it but it is not get all the power to the wheels. It sounds like something is grinding or not make the contact that it needs. It is moving but still sounds like the gears are not making full contact with each other . It is not moving full speed the motor is ripping but it will not go very fast something is not right. PLEASE HELP
What kind of vechile? Slipper clutch? did you check the clutch? Possible loose grub screw on outdrive(s) Center diff shimmed wrong? Could be lost of things. Giver more info please.
OK sorry it is a Monster gt with a mach 427 motor. have check the rear end the grub screw and drive train. I h don't know how to check the clutch or i would it started doing it the other day. So i have been trying different thing to fix it but no luck yet
OK thanks for your help.
