E-Maxx Advice
#16
You've all pretty much convinced me to go with the Mamba Monster Max and 2200kv motor... I'm still not sure about a few things though:
How many teeth should I have on the hardened pinion? I have 7-cell (side-by-side) batteries with TRX connectors, I'm guessing these will need to be connected in series? What connector does the mmm use for the battery?
Thanks again
Thanks again
#17
The MMM esc comes bare, you add the connector you want, in your case a TRX connector to go with your batts. Yes, you want to run them in series. You'll also need a Castle link - MMM comes with auto lipo set to on and you need to disable it to run NiMh. You'll want the link anyway for fine tuning.
Castle is coming out with a field programming card "early this year" but I don't know then thats going to be.
I would use the same gearing as the Brushless version EMaxx is running. There is diff gearing based on the voltage that you're running - Here's the chart - they use 17/68 for NiMh -
http://www.traxxas.com/products/elec...peed_chart.jpg
#18
Not sure if the E-Maxx runs mod-1 pitch gears or not but if so the Losi pinions are some of the best out. They are hardened and coated to make them quiter than the rest.
#20
Thanks again
Thanks again
It would mean more connections, which I'm sure adds resistance. Not sure it would matter in the end though.
ben
