-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   E-maxx Wheels (https://www.rctech.net/forum/monster-trucks/342506-e-maxx-wheels.html)
porschejim911 11-07-2009 08:25 PM
Originally Posted by pinky2252s (Post 6577184)
Go to prolineracing.com or towerhobbies.com And look for 14mm wheels. Just do that. Dont go buy an adapter or anything just get the right size wheels. Im not sure why these other guys were telling you to get a 17mm adapter. Your fine with the stock 14mm and thats the size rims you should get
Now the hub size I assume means the wheels would fit on my truck? But unless they match the diameter and width of the stock wheels I assume they would be for a different size tire?
pinky2252s 11-07-2009 08:37 PM
The hub size is the size that fits on to your axle (trying to avoid saying your nut size, lol)
If it says 14mm 3.8 inch wheel then you find the tires that are 3.8 inches
Do NOT buy 40 series wheels UNLESS you have the 17mm adapter, then in that case you would also have to buy 40 series tires. But this is not your case
Also, If you are looking to buy BEADLOCK wheels (the tires are held on by many tiny screws) you must buy BEADLOCK tires (also in your 14mm).
Duster_360 11-07-2009 09:08 PM
If you just refer to it as a 14mm hex or 17mm hex, its pretty clear what you're talking about.....
I know its more expensive, but you can change wheels too - as long as they're 14mm hex, they will work.
I wanted lightest weight wheels/tires to reduce rotating weight and get the most reponse from the motors. Reason I went with SportTraxx wheels and tires. That dropped a bunch of weight off of my 3906, making it much more responsive.
V0RT3X 11-08-2009 12:25 AM
Originally Posted by porschejim911 (Post 6577117)
I'm not actually looking to move away from the stock tire, just find different wheels that will work with the stock tires.
Traxxas tires have a different bead so you can only use them with TRX wheels. Then you're limited with these rims:
http://www.traxxas.com/products/elec...ccessories.htm
It's best to change wheels and tires, you can use MT size (3.2) or stretch some MT tires onto LPR rims(3.7) for a lower profile.
Stock Emaxx wheels are similar to 40 series I think.(3.8?)
porschejim911 11-08-2009 06:13 AM
I'm really surprised that nobody else is making stuff the same size as Traxxas given how popular the E-maxx is.
porschejim911 11-08-2009 06:22 AM
Is there a size tire and wheel that most people would switch to? The stock ones seem to work real well. Just wanted to go for a different look.
V0RT3X 11-08-2009 06:45 AM
Look for tires in the gallery: http://monster.traxxas.com/showthread.php?t=210087
I'd go with MT size or 17mm JConcepts Rulux Half-ups offset wheels and tires of your choice (Masher or Badlands)
snowboard094 11-08-2009 12:52 PM
http://www.maximizerproducts.com/mod...fset_C3766.cfm
http://cgi.ebay.com/Traxxas-17mm-Spl...d=390112079646
http://cgi.ebay.com/Pro-Line-Badland...item2ea8eb43aa
porschejim911 11-08-2009 01:37 PM
Anybody see a problem with this combo?
http://www3.towerhobbies.com/cgi-bin...?&I=LXJG97&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXVBZ9&P=7
or maybe these tires instead
http://www3.towerhobbies.com/cgi-bin...?&I=LXVS54&P=7
pinky2252s 11-08-2009 02:01 PM
Originally Posted by porschejim911 (Post 6579617)
I dont see a problem with the first combo. But you will also need foams to go in between the tire and rim. These will work
http://www3.towerhobbies.com/cgi-bin...4971&search=Go
V0RT3X 11-09-2009 05:22 AM
Get Proline tires, as I said before TRX tires will only fit TRX wheels. And Proline's Mashers are probably more durable.:nod:
porschejim911 11-09-2009 05:10 PM
Thanks for the help guys. Any thoughts on mashers vs badlands? I'm mostly dirt, mud, and grass.
Also, are there any good reason to switch to 17mm? Hate to buy new wheels and then decide I want to switch to 17mm later.
snowboard094 11-09-2009 05:23 PM
The badlands are the best tire for bashing IMO. They are also very nice on pavement. I would highly recommend them.
Duster_360 11-09-2009 05:32 PM
.....Also, are there any good reason to switch to 17mm? Hate to buy new wheels and then decide I want to switch to 17mm later.
Unless you're having probs stripping 14mm, no, there's not a good reason to switch to 17mm.
