E-Savage steering tuning?
So.. I have a box stock E-Savage.. I'm trying to figure out if the steering can be tuned a bit.. Can't remember if it's oversteer or understeer but....
Under power, the front end pushes a lot. As soon as you get off the power it'll turn really sharp.
I'd like it even it out some.. Maybe even be able to kick the back end out while cornering..
You can grind the hubs and axle cariers to help with turning. Alot has to do with the toe and the camber of the tires too. The Hpi suspension conversion helps alot to with added castor. and decresed turning radius.
