OS CV R starting problems >
Old 06-29-2009 | 08:30 AM
Default OS CV R starting problems
I have a new OS CV R engine and am having problems starting it. The Fuel is getting to the engine, since it start to fire but will not totally start. In the manual they only have the factory needle settings for the needle valve but not the other 2. Also is there a better % of fuel to use when starting a new engine
BJAMES02 is offline
Old 06-29-2009 | 12:36 PM
Carb settings -
Needle Settings: High Speed: 2.5 turns out from fully closed
Metering Needle (low speed): .5 turn in from flush
with carb body
Throttle Stop Screw: 1mm open from fully closed
Other info can be found here -
http://www.osengines.com/index.html
Duster_360 is offline
HTML code is On
