e-revo newb
Old 04-25-2009 | 01:33 PM
9six7nine2bOI's Avatar
Default e-revo newb
i just a got a e-revo n i wanted to know if n e one else who has a e-revo is having battery overheating problems....after bout 5 mins. my batteries are really hot n i have to let them cool b4 i continue running...n e suggestions, also will i loose performance if i run just 1 stock motor? BTW i am using deans plugs and i wanted to know if u need to use the traxxas plugs
9six7nine2bOI is offline
Old 04-25-2009 | 01:47 PM
infernus1986's Avatar
Your problem is probably related to the batterys your using 7.2V 4000mah is the least you can run with it.
even with those batts the E revo leaves much to be desired as me and my friend where very displeased with its performance.
infernus1986 is offline
Old 04-25-2009 | 02:44 PM
o ok.....have u heard of tenergy? i was looking into building some 7 cell packs with those batteries but i wanted to knowif there n e good:
http://www.all-battery.com/tenergypr...variation=2743
Old 04-25-2009 | 02:52 PM
well i was researching and those cells are trash, i think ill have to go with pro-match energy cells
Old 04-25-2009 | 02:56 PM
Wow, that was close....I made the tenergy mistake - pr of 7 cell Emaxx pacs that were rubbish. Def give Promatch a look, reliable builder with good quality cells that always seem fresh.
Oh yeah forgot - hen batts get hot, usually means they can't deliver the amps. Either cheap, old and worn out or bad cell in what was a good pac.....
Duster_360 is offline
Old 04-25-2009 | 04:19 PM
yeah i was thinking that the batteries could not supply both motors... yeah i think im gonna pick up some promatch ener-G 7 crell matched packs soon thanx for letting me know bout the shitty batteries...
Old 04-26-2009 | 05:39 PM
tbh if your gonna spend some money on batteries go lipo even tho they sound like more of a hassel then Ni-Mh packs they actually much better.
Your more likely to have problems with the nimh packs down the road getting outa balance,dead cells and the lipos are much better suited for a large heavy truck like the E revo.
Not to mention much lighter which is something the E benefits from greatly
I speak from experience on the fact NiMh packs are just not suitable for a vehicle the size of the revo if you actually want to enjoy running your truck
Old 04-26-2009 | 07:01 PM
snowboard094's Avatar
+1 infernus
You wont regret going to lipo. I have had my lipos last for over a year and only balanced them 2wice.
snowboard094 is offline
HTML code is On
