Savage help Needed Please
Hi everyone
just before christmas I ran my savage afterwards I did the after care and put it away I decided to get the truck out and blow the dust off the other week but when I came to use it there was no steering or anything else the battery indicator for the humppack battery say's the battery is fully. charged the hand set batteries so they are fully charged I just can't understand why there is nothing at all, sorry all I get is the wheels twich when it's turned on and thats it nothing else.
any help would be great
thank's
Neil
thank's
Neil
hi neil there could be a number of things to check 1 st being that all the ends are secure in the receiver box 2nd could be that the servo has broken 3rd could be that you mite of had a wack on the front and you need to take the servo saver off and reajust the trip before re assembleing it also the servo horn could be stripped inside
Personaly what i would do it remove the servo saver and see if the servo is working then if its not then id say you need to replace it
Hope this helps
Hope this helps
so your saying that your steering servo and your throtle servo are not working? If they both are not working I would have to say either your reciver is shot or by some odd chance both of the servo leads are unpluged or damaged in some way. if it's just the steering thats not working and you can here the servo moveing when you turn the wheel on the radio then I would say the gears are shot in the servo wich is common in the stock servo they are plastic and cant handle the big wheels
. Just dont start beating me up on spelling also. hahaha
