diff/axal? T-maxx >
diff/axal? T-maxx
diff/axal? T-maxx
Old 03-26-2008 | 09:53 PM
pinky2252s's Avatar
Default diff/axal? T-maxx
ok so i just replaced the bulk heads and cleaned and regreased my front diff and i took everything apart and got most of it back together fine except one thing
you have the diff in your hand, there are 2 out put shafts that come out on each side, then you put another sort of axal i guess you could say, that goes over the output shaft and it basicly extends it and it goes to the the out side were you put a couple pieces on and you put the wheel on it. so my problem is, is that the "axal" that goes over the output shaft gets stuck like 1 inch to long so the diff cant fit snug in the bulk head, ive tried WD-40 and i got sort of far but not far enough
how can i get it to get farther down so i can run it tomorrow?
thanks guys/girls
Tyler
pinky2252s is offline
Old 03-27-2008 | 11:58 AM
pinky2252s's Avatar
anyone?
Old 03-27-2008 | 12:37 PM
badassrevo's Avatar
Try it on each spline until you find the one that it slides freely on .
badassrevo is offline
Old 03-27-2008 | 03:34 PM
dieseldog20's Avatar
is the diff completely inside the housing??? so all you have sticking out of the case is a piece of metal about a half inch long? your question is kinda confusing. but we will see what we can help you out with.
dieseldog20 is offline
Old 03-27-2008 | 11:34 PM
pinky2252s's Avatar
i figured it out, i just used a clamp on my work bench and a little persuasion with a hammer
Old 03-28-2008 | 07:53 AM
glad you could figure it out.
HTML code is On
