liftoff
Old 06-25-2003 | 08:18 PM
Default liftoff
Hey, got a little stearing prob, if any of you can help. I have a duratrax st pro, and when I'm under heavy acceleration, the front right (passenger side) tire rides about 1/4 off the road. I've put better shocks on, and nothing I seem to do makes much difference. I guess if it aint gonna do a wheelie, then I'd just rather keep the fronts down so I can turn!
Also, this tire seems to liftoff in the corners too.
Any help out there would be good.
thanks!
torq is offline
Old 06-26-2003 | 02:46 PM
newracer's Avatar
make sure there is no binding in your suspension and both shocks are equal length
newracer is offline
Old 06-26-2003 | 04:50 PM
stiffen rear springs
SteveA is offline
Old 07-02-2003 | 03:57 PM
metal gear 2010's Avatar
or add spacers. You could also change the shock oil with silicone oil and increase the weight
metal gear 2010 is offline
Old 07-08-2003 | 03:36 PM
DuffMan's Avatar
If there is anyway to push the electronics or batterys farther up on the chassis id give that a try.
DuffMan is offline
Old 07-29-2003 | 08:00 PM
Sounds like the chasis is flexing under the torque load from the hard acceleration.Look into stiffening the chassis.Actually this is not a terrible thing ,at least it shows that you have the engine and gearing dialed in.
maxxsacrifice is offline
HTML code is On
