You can use any number of packs/cells , but it is customary to use 1 or 2 packs totalling 8-24 cells. I normaly use the max number of cells that esc will handle.
get a vxl and a 3s lipo. youll be running faster and longer than you ever imagined
That would not be a good choice for an e-maxx. A larger brushless system would be in order.
my set-up...
E-Maxx. VXL system with Integy motor fan heat sink. MaxAmps 3s 5000 lipo. RPM Monster claws wrapped in Pro-line badlands. CVDs all around so i don't keep ripping my axles apart. performance... Shames every T-Maxx 3.3 its gone up against. wheelies at any speed. backflips on takeoffs. against a Maxx with the novak HV4.5 system and 4s.... im faster. temps are fine and run times last anywhere between 20 and 25 minutes. doing a speed run, my tires ballon so much that they rip off the rims and even the foams blow out... |
| All times are GMT -7. It is currently 06:04 PM. |
