E-maxx Cuts out and stops moving >
Old 07-03-2007 | 09:29 AM
Default E-maxx Cuts out and stops moving
I got one for you fellas. I am having esc issues with my e-maxx. it is cutting out while I am driving. Some times it compltely cuts out and only will move again when I Shut the e-maxx down and turn it back on.
Any suggestions?
scrolanky is offline
Old 07-03-2007 | 10:50 AM
4wdmt's Avatar
It "might" be the thermal protection of the ESC kicking in. Check for binding in the drivetrain or it's an overgearing issue.
Do you drive full throttle all the times?
4wdmt is offline
Old 07-03-2007 | 11:44 AM
not at full throttle all the time. I am just ripping around my yard. I'm going to disassemble the truck again. I just pulled it apart and replaced the spur gear and checked the tranny as i was having troubles shifting but got that fixed. I'll check those though. Thanks
Old 07-03-2007 | 09:49 PM
4wdmt's Avatar
Ok, lets see. What gearing (spur and pinion) are you using and also the tires. BTW, is the place where you run your E has lots of tall grass?
4wdmt is offline
HTML code is On
