major glitching when i install hitec on gst >
Old 02-05-2007 | 09:14 PM
Default major glitching when i install hitec on gst
i wanted a faster and higher torque servo in my cen gst 7.7, so i installed a hitec hs-5945mg servo. i'm getting weird behavior though when i install it. i get major glitching all over the place and my 1400mah receiver battery dumps after only like 3-4 mins of driving. i threw back in the stock cen servo and everything is back to normal. no glitching and longer receiver pack time. with the hitec servo installed, it performs flawlessly with really good speed and torque, but with glitching and battery dumping. what's going on?
nismoflip is offline
Old 02-06-2007 | 03:52 PM
Cain's Avatar
Tech Legend
what radio are you using? Also, have you tried a different receiver pack? Give hitec a call as I have heard of glitching issues from the servo, but its aways good to work back from the common points to identify the root problem.
Cain is offline
Old 02-06-2007 | 04:42 PM
i'm using the stock skyion dsx 3ch am pistol grip and an intellect 1400mah hump pack. i'll try another rx pack and see what happens. someone told me to try wrapping the hitec wires around a magnet to help with interference. is there any truth to that? thanks
Old 02-06-2007 | 07:06 PM
5945mg? mg stands for metal gear. Some digital mg servo's generate radio frequency when metal gears turn against each other. That RF noise or electric noise you hear can cause glitching especially in an AM radio. I'm no expert but the way I understand it is, digital servo's are better than analog (I can explain why but I'll need to read up on it again) but you need a good radio to make em work right.
eatmydirt is offline
Old 02-06-2007 | 09:15 PM
jayjay51987's Avatar
I had my servo glitch when i tried the jr metal gear servo, then i tried the hitec one and it fixed it, this was also with metal gears, its draining your batts, because it is a better servo and is using up more power.
jayjay51987 is offline
HTML code is On
