LST2 THREAD.
Old 08-16-2006 | 03:53 AM
  #61
FLATCHAT's Avatar
I HAVE A QUESTION ABOUT CLUTCHEs, are the alloy ones that come with the lst2 the best? cause i pulled mine apart to check it out and put the ti nitride gear set on but also found out that the clutch bell is not threaded, bummer and also the clutch and bearings were shot, so before i buy new ones. what is the best..
cheers
FLATCHAT is offline
Old 08-16-2006 | 04:36 AM
  #62
FLATCHAT's Avatar
also, do any one make roll over protection? like a roll bar of sum kind other then a rall cage cheers
FLATCHAT is offline
Old 08-16-2006 | 07:05 AM
  #63
2DMaxLST's Avatar
Link: you will find answers here..
2DMaxLST is offline
Old 08-16-2006 | 01:35 PM
  #64
FLATCHAT's Avatar
thanks heaps i posted on there hope fully i get answeres
FLATCHAT is offline
Old 08-18-2006 | 02:49 PM
  #65
Default mach 427 onewaybearing
just need some information onthe lst2's motor the mach 427,i'm just curious on the oneway bearing ,i went to ebay & i saw the bearing look like the ofna picco 27 onewaybearing starter too,is anyone know if this are exackly the same pls. help let me know thks
svagedrv31 is offline
Old 08-18-2006 | 03:14 PM
  #66
mach51's Avatar
i would say, "NO"...and if it did fit, avoid the Picco bearing because they have had problems cracking...
mach51 is offline
Old 08-18-2006 | 05:26 PM
  #67
thks mach51,i almost gonna buy it ,anyway on the ofna bearing issue,i heard it's pretty pricy
Old 08-18-2006 | 06:35 PM
  #68
mach51's Avatar
mach 26 and sportwerks bearing is only 11 bucks, dont know if the 427 one is the same.
mach51 is offline
Old 08-22-2006 | 04:50 PM
  #69
TripleX-JT's Avatar
Can the 2nd steering servo be removed in a LST2?
TripleX-JT is offline
Old 08-22-2006 | 04:57 PM
  #70
PDXLST's Avatar
From: I dont race that LST anymore I'm Just to lazy to change my Screen name
Not very successfully. Check this
PDXLST is offline
Old 08-22-2006 | 05:01 PM
  #71
sharkman's Avatar
No. the only servo saver is mounted on the servo. If you put all the stress on a single servo and saver, there is not a servo saver made that can handle the load.
Try taking off a servo horn off and drive the truck and see how much tension one can take before the saver kicks in and is overworked.
I broke a servo arm on my saver during a race and had alot of trouble turning left. The remaining saver could not turn the wheels with unloading. A couple of laps I almost went off the track at the end of the straight because the wheels would not turn, going to fast.
A couple of guys at lstforums have tried every which way to accomplish this and could not make it work. It just comes down to servo mounted savers are not strong enough to do the job.
sharkman is offline
Old 08-22-2006 | 05:30 PM
  #72
TripleX-JT's Avatar
Thanks a lot for the info. I checked out the lstforum and it was very helpful. I guess my only concern was if I wanted a high end servo for steering it is kinda of a waste.
From what Ive read the 2-590s or 2-650s will do the job just fine is that correct?
Old 08-22-2006 | 05:34 PM
  #73
sharkman's Avatar
You can keep the 590's in there with no problem. For the price of the 650's, they are almost double the torque of the 590's for only about $10 more.
I ended up buying two 650's and using the 590's for throttle/brake and spare.
sharkman is offline
Old 08-22-2006 | 05:40 PM
  #74
TripleX-JT's Avatar
What about 2-JR4800T servos for steering and a JR4800S for throttle?
or is that pretty much a waste of money?
Old 08-22-2006 | 05:51 PM
  #75
sharkman's Avatar
Save your money, the extra $60 you can save with the 650's will allow you to get more hop ups. Check this out
http://lstvideos.com/forums/viewtopic.php?t=49
sharkman is offline
