Throtle problems >
Throtle problems
Throtle problems
Old 06-19-2006 | 04:42 AM
Bigwattsus's Avatar
Unhappy Throtle problems
I just bought my truck broke it in like I was supposed to. Today I tried to adjust high speed and idle settings I having problems. When accelerate it takes off really slow. Then the transmission won't shift out. Can someone help?
Bigwattsus is offline
Old 06-19-2006 | 05:18 AM
Rookie 4.6's Avatar
What truck/motor do you have? Have you only adjusted the HS needle? Does the truck idle ok? Try to give a more descriptive post as it will make it easier for people to help you.
Rookie 4.6 is offline
Old 06-19-2006 | 05:25 AM
Bigwattsus's Avatar
Post
I have a T-maxx 3.3 I had my friend try and help me we both fairly new to this. I adjust the idle and the high speed it idle fine stays running just when I hit the throttle it has the hesitation and won't shift into 2nd gear.
Old 06-19-2006 | 05:59 AM
Rookie 4.6's Avatar
First work out how many turns your LS needle is set at. Now try turning it out half a turn, because if this needle is to lean the engine will bog down on acceleration as it is not getting enough fuel. If this makes it worse set back to the original setting then try going in quater of a turn, because if the engine is getting to much fuel on acceleration it will cause the engine to flood and bog down.
How many turns do you have the HS needle set at?? Also have you replaced the glow plug since run in?
HTML code is On
