Engine for Production MT Class ? >
Old 02-06-2006 | 02:58 PM
Tabushi's Avatar
Default Engine for Production MT Class ?
Hi guys,
As i want to change my engine (Stock OS-Made .18 engine on my Tamiya TNX PRO) in about a month or so ... i was thinking on the CVR-X or the TZ-X ... but now this engines came to my mind :
1.- Team Orion WASP ENGINE 18 PRO (Side exhaust, STD shaft, Slide Carburator, Pull Start). 1.50ps power declared.
2.- Associated LRP Z.18S Pro Engine. 1.51ps power declared.
Do you think they are compared to the OS alternatives ?. The Team Orion is not on sale in USA, but i can buy it from Europe ... "i think" its a good alternative to the TZ what you think ?
thanks for your comments,
Tabushi is offline
Old 02-06-2006 | 11:42 PM
mr-e-maxx's Avatar
Cool
Im not sure about the LRP Z.18s, but I did put a Orion Wasp .18 Pro in one of my Terra Crushers. It has good bottom and mid but nothing on the top end not like the TNX .18. I have a O.S. .18-CVRX in one of my TNX's and I like it alot, a little better the TNX .18. But if you need a lot more power I would recommed the O.S. .18-TM (I have one in one of my TNX's) the TZ is alittle over powering for a lot of tracks, but it gets better fuel comsumption than the TM.
mr-e-maxx is offline
Old 02-07-2006 | 04:52 AM
Tabushi's Avatar
Thanks MrEmaxx ... but ... the TM engine need mods right ?, cause its not standar crankshaft ...
Tabushi is offline
Old 02-07-2006 | 07:36 AM
stevenmichael's Avatar
Originally Posted by Tabushi
Hi guys,
A buddy of mine has a TNX and he has a CV-RX in his,dropped right in all of them should drop right in as long as you get the model with the proper shaft.
the cvr came about because of the work OS did with the motor that comes with the TNX,the TM is the next step and it is even quicker the TZ is an absolute missle for an .18.
the orion is made by a taiwan company that also makes team infinity and STS not high on my list when i speak of quality,go with the OS you will not be dissappointed the TZ is a little warmer than the TM but they are very close.
OS is known for thier ability to hold thier tune and with this new era of power they are putting out they absolutely scream
good luck
steven
stevenmichael is offline
HTML code is On
