Aspen Park Raceway 2012 Brandon, SD
Old 04-20-2012, 05:36 PM
  #16
Yes. Weather permitting around 10:00.
vigorcs90 is offline
Old 04-22-2012, 07:00 AM
  #17
I stopped out this morning. Track is to wet to run around with a skid steer. Let's try again next Saturday and Sunday to get it ready.
Old 04-24-2012, 08:53 PM
  #18
If anybody is available to help on the track tomorrow night it would be great. I hope to be there around 6:30.
Gil
Old 04-30-2012, 09:28 PM
  #19
Default Sprint Cars
What gearing does everyone run on the oval for sprint cars?
I might get the klien up and going. Thinking a .12 engine...
Pinion/Clutch & Spur thoughts?
Thanks,
Nate
nateh is offline
Old 05-01-2012, 09:20 PM
  #20
Default Track Prep
Jusy FYI will try and work on tracks on Saturday Weather Permitting. There has been people going out there in the mud tearing up the track, and then wiping there feet on everything. The track is locked up till it dries up. So to get any racing in this week will require some dry days to get tracks ready.
Nate gearing with Buggy rear tires I run 62 spur 23 bell you can drop two teeth on bell for truck rear tires. Thanks Jason
TRCHOBBY is offline
Old 05-01-2012, 10:10 PM
  #21
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
Got some stuff forsale!
http://www.rctech.net/forum/10680122-post2064.html
BSchorr is offline
Old 05-05-2012, 03:47 PM
  #22
dfsc10's Avatar
Trader Rating: 22 (100%+)
track had a bunch of puddles i dont think it will be dried up by tomorrow
dfsc10 is offline
Old 05-05-2012, 03:52 PM
  #23
With no sun, cold weather and a chance of more rain tonight we are calling off the races for tomorrow.
Gil
Old 05-05-2012, 06:03 PM
  #24
TrailblazerSS81's Avatar
Trader Rating: 16 (100%+)
Hay Gil, can you put a roof over the track?
TrailblazerSS81 is offline
Old 05-05-2012, 06:05 PM
  #25
Sure. When do you want to start?
Old 05-05-2012, 07:48 PM
  #26
dfsc10's Avatar
dfsc10 is offline
Old 05-06-2012, 05:07 PM
  #27
what are the rules there. i have traxxas slash 2wd all stock brushed motor.
harleyracer99 is offline
Old 05-08-2012, 05:58 AM
  #28
Jason or anyone else running a Klein Sprint,
This probably sounds like a stupid question but I'm stumped...
I mounted a motor into my chassis last night and have 2 issues.
1 - The clutch bell is rubbing on the chassis. Easy fix add spacers to move the motor up a bit.
2 - Even with and without the spacers, the fly wheel sits to high to hit the bump box wheel.
Any thoughts on how to address this issue? I really don't want a roto start since I would have to then buy a new motor...
Thanks!
Nate
nateh is offline
Old 05-08-2012, 11:09 AM
  #29
Nate,
I know on my Klein sprinter the bottom of the flywheel is slightly above the bottom of the chassis plate - it needs to be that way so you don't kill the engine when the chassis bottoms out on the dirt on bumps. I don't need to run any spacers on my engine mounts to make the clutch bell clear the chassis - maybe it's a difference in your motor/clutch combo? You may need to grind out the chassis opening a little to achieve the clearence. In regards to engaging the starter wheel and flywheel...this can be a ricky setting. the starter wheel needs to be exactly in the center of the flywheel opening to allow it to enter the opening as far as possible. If the starter wheel is worn (smaller in diameter) it can be an issue. I have been known to shave the starter wheel mounts to set the starter wheel up a little higher to compoensate for wear. Starter boxes can be a real hassle sometimes!!
Hope this helps....
Jerry
blackcloudracin is offline
Old 05-08-2012, 04:30 PM
  #30
Does anyone want to do a test and tune on Sunday around noon
