On-road @ TCHR
#301
Are you sure you link is right ? It is not working for me.
I was talking to a guy from Roar, and he suggested the possibility that the speedo's would be programed right at tech, at big races. That is making a assumption that it would be possible to do this, with a number of different mfgs going in different directions.
#303
Sim, how did the BL work?
I couldn't make it last night due to the fact that SOME Iowan's are stupid.
#305
Trader Rating: 32 (100%+)
Hey guys me and a budy are thinking about comming up this saturday do you guys have a stock TC foam class on saturdays? Also are you guys practicing this sunday aswell? Thanks for the info and I will see you guys this weekend hopefully.
#306
kevin k
saturdays there is a sportsman stock rubber class, an expart stock rubber class, and an open class that has been 5 min mod foam latelybut as the name says, open so u can run stock foam in it.
#307
Ok thanks and will you guys be open sunday for practice? and at what time?
#309
Thanks Jeff
#310
Kevin,No Problem!!!
Just got done putting together some 3300's for 1/12th scale, they felt heavy in my hands so I decided to weigh them after putting them together in 4 cell packs. I was right, mine weigh .6 oz more than a pack of panisonics......Time to put the car on a diet again.
#311
but theres pink on them
#313
Saturday night MOD FOAM SEDAN
Who's in?
#315
BTW: I ran the Brushless..
First Impression:
Great throttle reponse! and tons of torque. The throttle is extremely linear and the brakes come on very smooth and can be applied so hard it makes the belt skip. I am a impressed with how well the system works and everything that has been said about these designs are not true. However it doesnt have as much speed and performance as I hoped. It seems to be at about the same speed as a 17 turn. I am a bit disapointed up front but I have a feeling something is not configured properly to get the most out of the motor. (I only got to run practice for 5 minutes) It seems like it is running half speed.
I thought you guys would like to know an early report. But however the verdict is still out.
Shawn
Shawn
