**xxx - Tchr - 2**
#46
San Fran looked pretty tough last night, no 81 may give da Pack some steroid induced fits.
#47
XXX BK2
The new car is out! and its dialed! new diff is WAY better, tranny is sweet, new adjustments rock!!! here is a set-up that I found to work awesome* at our track that takes advantage of some of the new adjustments.
* If you don't like steering, stick with a set-up similar to the box stock set-up. If you want the car to be capable of getting around the track the quickest at the exspense of a little smoothness, stability and overall driving ease, then give this one a try! Remember no matter what car you have, if it is set-up to be cabable of turning the fastest laps possible, it is rarely a set-up that is going to feel easy to drive (especially on our track)
Front-
shocks- 27.5 wt oil - 57 piston - .090 limiting inside shock - orange spring - #2 tower - inside arm
3-b camber link (1 washer under stud) - no bumpsteer washers - 30 deg blocks - short arm - spindles down - -1/2 deg camber - 0 deg toe in/out - 1/2 ounce led in front of servo to calm the car down.
Rear-
shocks- 25 wt oil - 56 piston - no limiting - pink spring - #2 tower - middle arm
2-a camber link - 2 deg anti-squat (2 shims) - hubs centered - long arm - -1 deg camber
tires-
front- Losi 7204 Pink full rear stock losi foam
rear- Losi X-2000 Red Trinity Bomb 1 firm foam
Front-
Rear-
tires-
#48
XXX-BK2 Set-up Winter '04
Here is a Set-up that Chad and I have been running, it is super dialed!!!
Front-
Shocks- 25wt oil - 56 piston - silver springs - .090 limiting
hole 2 on tower - inside on arm
3-B camber link with 1 washer - 30 deg caster blocks(stock)
short arms - spindles down
1/4 ounce weight in front of servo
-1 camber
1 deg toe-in
Rear-
Shocks- 25wt oil - 55 piston - red springs - no limiting
hole 2 on tower - middle on arm
2-A camber link - 2 deg anti-squat (2 shims)
hubs centered
short arms
-1 camber
Pro-Line M3 Square Fuzzies Trinity Bomb 1 firm foam (grey)
Front-
-1 camber
1 deg toe-in
Rear-
hubs centered
short arms
-1 camber
#49
Dogbones are super dialed! put them on!!!!!!
#51
I have also been running this setup for a while now, and after a lot of testing I keep coming back to it.......
#52
ANYBODY WANT A MUFFIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#53
Yea, that setup works pretty good for me too.
#54
YOU KNOW IT DOES!!!!
#55
Chad gives it two thumbs up!!!
#56
I Wish I had two more arms so I could give those set-ups FOUR thumbs up!!!!!
#57
You got something else that points up!!!!!!!!
#58
#59
When is this race? Do you guys have a web site or something?
#60
I would like to know Marshall Skare's set-up for the Team Losi XXXBK2 at TCHR. Thank You!!!!!!!!!!!!!!!!!!!!!!!!
