New: Losi Mini 8ight Desert Buggy
#61
The Losi minis and the LC Racing/Tacon vehicles all get rocks in the plastic spur gear. I upgraded to Hot Racing hardened spurs and pinions on all of mine. No more dirt problems after that.
3s is really fast but if you have throttle control it's not a problem. I suspect the esc will have problems on 3s. The Hobbywing 60a esc is a good replacement.
#62
I got mine e cleaned up and installed new spur and pinion. Loads of tiny rocks in there! I did get the mini T wheels to go on with some modification but they are rubbing on the body. They look cool but would need a different body without the roll cage for it to work. It does look like the truggy body mount kit will work as its listed as a compatible part!
Ill keep this off of the dirt...2 hours worth of clean up and gear replacement was a pain!
#63
Is there some sort of way to cover up the hole that allows dirt in?
#64
#65
#66
Like this buggy but Kind of a bummer about the dirt.
#67
Do you have an air compressor? We run our minis on our loose and semi-dusty backyard track and keep the trucks perfectly clean with just an air compressor. We carefully blow down the whole truck between every battery and the trucks never build-up enough dirt that the compressed air won't knock it all off. Easy as can be.
#68
You have to take the whole rear end off to change the pinion?
#69
#70
#72
#74
Mine arrived today. My lipo won't be here until Monday so I'm stuck with that nimh garbage. I've only driven it on pavement and I like it a lot. Not satisfied with the battery. Once I get that 3s hopefully it'll scream. I see the electronics getting replaced sooner than later. I'll push it to the limit with the stock electronics and see what happens. Servo is weak is there a replacement yet that's a direct drop in?
#75
Let me know how the 3s works. As far as electronics, I'm just getting back into this so I don't have any comparison but at least I could tell that eventually I'd like a bit better setup.
