New HPI Micro RS4
Old 11-19-2013 | 03:43 AM
  #61
Originally Posted by adanmtxt1
Nice pick up Geppetto! I remember when the MRS4 was released, the kit version was $99.
Does your KB version come with normal sticky rubber tires or slick drift tires?
Thanks. It came with a rubber tire. I was hoping to get a drift set, but apparently the KB version is not considered "drift", where the Mustang version is specifically drift. Right now, there does not seem to be a lot of parts available. As soon as I can find them, I'll get drift tires.
Geppetto is offline
Old 11-27-2013 | 12:32 PM
  #62
ordered the drift version this morning, see how it compares to my original skyline from 8 years ago
Fuzzymk5 is offline
Old 11-30-2013 | 01:38 AM
  #63
SuperFastSnail's Avatar
Default Size comparison HPI Micro RS4 vrs Carisma GT4
The size between the two are quite different but if I mate the HPI Micro RS4 with the same brushless setup using a big block conversion, I believe the Micro RS4 will haul big time and drift superbly.
SuperFastSnail is offline
Old 11-30-2013 | 02:35 AM
  #64
MrUnlimited's Avatar
What car is that touring car? Carisma? What size? 1/16 or 1/14?
MrUnlimited is offline
Old 11-30-2013 | 03:11 AM
  #65
targetingxmod's Avatar
Can a X-RAY M18 Pro use those rims and bodys?
I would like to know principably the rims/tires.
Is there a hex in there? What size... any pic is aprecisted!
targetingxmod is offline
Old 11-30-2013 | 05:08 PM
  #66
I believe the Carisma touring cars are 1/14th scale. With the Dynamite mini brushless system from the Vaterra and Kalerhari, the cars are excellent drifters and they are super fast.
As far as wheels and mounts go for the Carisma vehicles, the wheels fit into the bearings of the front and rear hubs and they look like a triangle. I will include some detail closeups later this evening.
Old 12-01-2013 | 02:19 AM
  #67
What shocks are they on the carima gt14 MK2? I know Ofna had a similar car but with nascar bodies.
Old 12-02-2013 | 11:04 AM
  #68
Ed Anderson's Avatar
You should have no problem finding the drift tires... That's the only part that's everywhere. Its the rubber tires that are hard to find. I think the tires that came on yours have a new number... not sure what compound they are.
It took me a while to warm up to this car... think it sat in the box for a year before I used it. ... Now we have a blast racing these.
Ed Anderson is offline
Old 12-20-2013 | 03:58 AM
  #69
Nastyboys727's Avatar
the bodys yes but if you got the tru pro with the wheel nuts you gotta get the rtr m18 wheel setup to use the hpi rims I got the rtr m18 and xray still sell the m18 line
Nastyboys727 is offline
Old 12-20-2013 | 07:50 AM
  #70
were the ol' micro RS4 any good to drift?
rcyoy is offline
Old 12-28-2013 | 09:56 PM
  #71
adanmtxt1's Avatar
Does anyone know if the standard plastic front differential gears are available anywhere? Mine finally stripped out and I don't have replacement parts; I've found out the just how hard the front one-way tears into driveshafts so would prefer to run a gear diff, but don't recall if anyone else made front diffs.
Edit: took a picture this evening. Penguin 3500LM chassis, Mamba25, rear ball differential, green front springs, thick grease in front diff, medium tires all around, Honda NSX body with the formed plastic wing, metal-geared micro Hitec servo.
Micro RS4 HD by Lunitic, on Flickr
adanmtxt1 is offline
Old 12-29-2013 | 05:08 AM
  #72
I need one too I seen them on ebay but there is a front onewsy for it too im hopping gpm is goin to start back making parts for them or any other after markets do
Old 12-29-2013 | 05:10 AM
  #73
Originally Posted by bigb11
new ratzas lipo chassis
who sells this chassis
Old 12-30-2013 | 05:02 PM
  #74
DarthRacer's Avatar
I have the new drift version. It has locked front and rear diffs! If I ever race it I'll need diffs. It looks like you can still get GPM rear ball diffs but like the posts just above me I'll need something for the front.
Has anyone found a good source of grip tires for these?
DarthRacer is offline
Old 12-30-2013 | 05:12 PM
  #75
FullMetalGrave's Avatar
I have the new drift version and so far I'm not really impressed. It definitely needs more power so an upgrade will be in the works
FullMetalGrave is offline
