"targetingxmod" Losi mini 8ight
Allright, blah blah blah... last christmas my own santa gave me this
Enough talking....Photos!!
-Inside the box it came!!
-Size comp to an mr02 from Kyosho! (yep, i am into micro or mini rc's)
-Second 20cm jump, bad things had happen. Shame Losi.
On second jump with 20cm ? Come on! TOY?
Shame. SHAME! Haven't your all drive this thing on practice trainging before relising it to the shelves?
-Traxxas eyelets solve the issue!
-3s (only accpeted speed for me)
Just like that!
-You know this... to not break the upper eyelets! Works very very very well!
-Tires are bold. Nevermind i do not race, just play around, somekind of bash! Mostly every speed run i can...
On 3s this thing gets hot, so what to do?
-7.4v 45c, gets out...
-Now after the 3s ends, the esc and motor are warm! Just need care on the remote, and not drive like a troll
-The fan ok, and safe... from chrashes...
-Sway bar kit! On 3s power it's needed... we don't drive like a troll anymore! Much control. Only problem is the stock ESC making 0-100% throttle!!!
-CF mud guards to keep shocks and rear clean!
And i saw a clicking noise today... check it close and it was an outdrive loose!
Time to open the diffs, lub them and screw the outdrive if not yet screwed.... ants:
-CF Mud guards brand...
-The eyelets that broke and the traxxas ones... The traxxas never brooke on me now!
-Li-fe Power for the remote! 3.3v in series!
-Life 6.6v power. More +-30meters range! Which is actually a good thing.
It's working for 3 charges by now. I dont' know if it will burn something on the remote. But for now is good. And i am waiting for the GT3c or the GT4, so no worries! (CORRECTION KYOSHO KT201)
-Plastic on the side where the pinion/spur lives! Keeps dirt out of it Getto style working!
-These bumpers save the car big time!
-More ground clearence! 1/10 buggy rims/tires.
Videos:
-Super mega ultra grip tires, awesome!
-19T pinion!
-Het 4800kv motor on 2s for now! (did not like this motor, at least with that ESC)
Just playing around with some stuff i got...
-Outdrives Lighter and stronger!
-3s 60C. Worth every penny. It kicks and draw power like a dinosaur till she ends!
-This should had been the first upgrade... but what the heck! It's now time for some straight lines.... the stock servo saver is junk... so i used an Xray servo saver instead of the photos.
could someone tell me what the spring rate(soft,medium or hard) is of the kit shock springs?
thanks
thanks
I wish I knew about the spring rates. Kind of difficult to tell....looking at the mini-8 parts on amain website. They have three different part numbers for front springs and also three for rear springs. Some are rated hard, some soft, perhaps the others are medium? I wish they cared enough to tell us.
Hey TargetingXmod man!
I like the photos of your car with the two fans. Does the losi esc work with other motors? You must have driven a lot of miles to wear the tires bald. I like all the different parts you are using. Great photos!
Suspended
hey. you got the sway bars from hot racing. is it just the same quality as the sway bars from losi? thanks
Hope that helps... that's my experience.. others may think different...
