Tires for Mini 8
#136
The desperados rim are all alike? i mean is there versions of if, with offset? Or just one offset?
As for stress, just install the losi upgrades outdrives and cvd's and ceramic bearing and up you go with a smile!
-1/10 on road Rims and tires for 1/10 buggys
-1/10 Rally tires for Kysoho DRX tires/rims combo. Rims will rub but with a little sand or getto workout they will be fine!
#138
Did the original Camaro rims fit on the M8?
#139
#140
Put Proline dirt Hawgs on it for the mini Revo trust me its what's on mine it's boss and if you want to see it look at my mini light build.
#141
Mini 8ight
Is it safe to assume any 12mm hex 1/10 touring wheel with 3mm or MORE offset will work for the Losi Mini 8ight?
Thanks in advance
Yuba
Thanks in advance
Yuba
#142
http://www.hpiracing.com/en/product_category/W10TW
i've had great luck with their tires as well.
http://www.hpiracing.com/en/product_category/W10TT
#143
[QUOTE=srootster;12405053]true statement. HPI seem to have the best selection that i've found. 1/10 scale touring / 12mm hex / 3-9mm offset / 26mm is what you're after.
Thanks so much. I am having a really hard time finding reasonably priced alternatives. I have some old HPI RS4 foams I wanted to run but I think they were 0 offset because the car literally wouldn't move.
#144
i've ran 0 offset rims in the past. what i did was remove the wheel hex and pin and add washers between the outboard bearing and pin to take up the slop, thus moving the hex outward when installed creating the required offset. it actually helped the car track better by removing the slop so i left the spacers in even with 3mm offset wheels. if you pull a wheel and the hex off and pull back and forth on the axle, you will see what i mean. there's a ton of slop.
so basically:
wheel bearing / 2 or 3 thin washers / pin / hex / wheel.
these are very cheap 0 offset wheels and tires i got off hobbyking. HPI tires are so much nicer though and grip 100X better. the radials and belted tires are amazing on asphalt and they have some great offroad tires as well.
you can see how tight the fit is, but they did clear after the spacing.
so basically:
#145
Nice Ride, I like the read accents.
I will definitely give that a go. I remember my Nitro RS4 would just stick to the road with foams. Have you found any cheap alternatives that would work?
Foams on asphalt are sweet and surprising last a long time.
Yuba
Yuba
#146
The Toyz has recently added a lot of wheel/tire options.
http://www.thetoyz.com/losi/Wheels%2...95/590/SubCat/
#147
Thanks Skiboblitch. I was emailing their support and the guy was telling me their web site was jacked up. He actually could NOT tell me what tires and rims worked with the mini 8ight. Seemed like I was getting India or something. srootster was super helpful by confirming the size/offset. I am rocking now.
#148
Hi guy's could anyone tell me the right tyre for carpet racing and do you have any links to shops.
thanks in advance.
thanks in advance.
#149
#150
Thanks for the reply i now have a good starting point.
Thanks for the offer on a set but shipping to the uk would cost a bomb thanks anyway .
