LC Racing EMB-1H Official Thread
#376
#378
My curent setup!
#380
The body is a Carisma GTB
ESC is a Sanwa Super Zero Vortex (it takes only sensored motors)
Motor is Nova 380 sensored micro 10,5T and 13,5T, i build and rebuild from different motors now since they stopped makin them!
Other options is:
3-racing red aluoptions, titanium turnbuckles, titanium screws, tefloncoated balls, RPM ballcups, Billans (Swedish constructed) carbonfiber parts, losi mini8 battery holders, Carisma GTB batterystrap, Xray 1/10 wing,alu rear turnbuckles, alu lower servosaver arm.
Modifications: Flipped rear arms to get shocks infront of tower and longer wheelbase, Chimsed wheel axles, Composite (original) chassis softer then original aluminium, plate mounted servo with cut wings on servo gain room for esc.
And some more!
#381
is there any binding with the flip arms.
Thanks!
Other options is:
And some more!
Other options is:
And some more!
#382
more parts..still waiting for my springs
also does any one know if there are screws that are better for plastic my holes keep stripping.looking at the screws there fine for aluminum parts.is losi screws different.
#383
#384
#385
#386
#387
what is the wheelbase now with the flip?
#388
Let us know how that motor mount works out. I was correct when I said that the Soar uses a different one, right? Hopefully it's better than that awful mount that came with the Valor. My Soar motor mount should be here today hopefully, then it's back to ripping it apart again. I think I am going to reinstall the gear cover at the same time. The main reason I removed it was because it severely interfered with the stock motor mount which then made for significant disassembly to just get the motor out or adjust gear mesh.
#389
#390
It must be much better to buy the kit buggy with all the options on and then build it to a "monster" or truggy!
