LC Racing EMB-1H Official Thread
#2792
Looks good! Are you going to run it off road? If so you might want to reinforce the front lip. It tends to take the most abuse and will crack pretty fast. I've never put the rear spoiler on my bodies. I'm curious to hear from you about how it holds up.
#2794
Nice looking rig! Your total amount invested in that heavily upgraded vehicle is still probably less than getting a stock X-Maxx or 8s Kraton. Probably the 6s Kraton as well.
#2796
What are the Team Associated Universals about?
I bought one of the EAC Engineering steering plates with the bearings pressed in and it's hard to tell how much it helps. I drove it yesterday and noticed that the inside tire doesn't flop around when turning like it used to do so it does have some impact.
#2798
Hi there, it's been a while...
had finally a couple of weeks time for some serious bashing, maybe it's just a coincidence,
but I'm kinda past two dozen 2S&3S battery packs and I didn't break any bearing since I'm using the crush tube solution.
Still, no Pics & Links so...
www-youtube-com/watch?v=zL7CP3GcNgc
Has anyone tried to adapt the motor mount from the Wltoys 104001?
#2799
#2800
I tried to do my own version of steering plates with the pressed bearings by drilling the draglink.
with it, the front wheel doesn't behave like they have different brains anymore.
more as an improvement I would say you make the EMB more squirrely than ever.
The downside is it is not really suited for bashing, at least not with the original draglink, since it lasted just a few battery packs.
#2803
#2804
